Does any one know the torque for the cylinder heads and for the head cover?
I am replacing the piston (standard bore) I did not notice much crankcase oil/lube at all. How much should be in the crank case.
Is it possible the bad piston (piece broke off ) and ba drings cause dthe crank cas eoil to possibly be sucked out or nurned up .
Thanks in advance.
Jim
Thanks in advance.
Jim
