1 - 5 of 5 Posts
hello everyone . I,m new to the pwc world. i bought the spi with the knowledge that it wasn't running right . the guy told me that he was out on the lake and it just died . would not crank ,beep or anything so i got it very cheap. got it home disconnected the battery and reconnected it and it beeped hit the start button and it fired right up!! yeeeaaa right ....wrong!! hooked up the water hose fired it up and turned water on and it idles great, half throttle runs great, full throttle for about 35 seconds and it just dies,kills all electrical and everything. I have to disconnect and reconnect the battery every time it does this like a reset but after i do that it its the same thing every time.Anyone have any ideas please!!!!!
Discussion Starter #2
ok on another note i have changed the fuel filters and replaced the old grey fuel lines ......runs good until wide open throttle ,,,maybe a rev limiter problem or cdi box?
Discussion Starter #4
running at about 12v at idol an increases with rpms.
took it down to the lake today an will not run wide open but will run great up to 3/4 throttle then shuts down ..ran for 45 min at half throttle to 3/4 throttle but shuts down everything anything above that.
Super Moderator
A charged battery just sitting should have 12.5 volts. Measuring voltage while running should be appx 13-14.5v.
Look and make sure all connections and grounds are good, tight, and clean.
1 - 5 of 5 Posts
