1 - 5 of 5 Posts
Last year my son took out our 1996 XP and it ran great for the first 30 minutes or so.Then he said it would bog out and on so he idled back to ramp.
I took out the gas tank and it had particles inside the tank so I emptied them and gas out thoroughly. What should my next steps be? I am thinking to start with the fuel filter and then proceed to the carb filters or the try to see if the fuel selector may have gone bad.
You should be ok once you have done that I used to have a xp. Probably best to fit a bulge pump if you don’t already have one fitted.
Discussion Starter #4
I ended up taking off both carburetors and doing a carburetor tune up and the jet ski works great. Those two little filters inside the carbs were clogged. Thank you
1 - 5 of 5 Posts
