I have an opportunity to pick up an older 96 STX 900 but the person who has it says it runs on 2 of 3 cylinders, and that the one cylinder has a broken rod. I'm a very capable auto mechanic ( not as a profession) but am new to working on PWC. My question is, is it worth investing the time and expense in this ski? I realize the crank probably has to come out so it would be a top and bottom end rebuild. They did say the rod did not come out of the engine. Should I just save my money and look for one that is a little simpler to get running? The budget for this is not huge for this project.
Any guidance would be appreciated.
Not huge, what is total cost of parts? Make sure you can afford it, parts are expensive. I just dropped $800 for manifold and exhaust pipe, gasket kit $180, $550 valve shims and timing. You have a good towing vehicle, trailer and storage, go for it . If not look after your priorities first. Remember it's a toy.
Thanks for the reply. I haven't researched the part cost yet, the ski is $150 bucks. I can afford it, I'm just not sure I should. The plan is to drop the drivetrain in an old boat and have some fun. Yes I can haul whatever I need, and can store as well. I was more concerned with complexity of the repair, and how much life the machine would have after that assuming nothing is cracked.
