I bought a 1996 waveraider 1100 that needed to be put together. The oil pump that was on it was cracked at the mounting flange. I bought another oil pump and installed it and started the engine. the oil pump cracked again.
what is going on?
I know the flywheel bolt is turning and the pump was in the slot when I installed it.
I do not know what else to check
I need help
Thanks
what is going on?
I need help
Thanks
