I have 1996 waveraider 1100 which I bought last it had the exhuast taken off and the fly wheel removed. I have the machine back together and I checked the compression in all three cylinderand they all read 110psi.
The engine runs and will accellerate out of the water with a flush kit. I put the machine in the water and it will idle but when I give it any throttle in seems to be running on one cylinder it sound terrible but the engine stays running. I have the engine running on premix 50 to 1 because the oil pump flange cracked. I took the fuel pump apart and looked in it to see if something is clogged but it looks fine. I am going to pickup a rebuild kit anyway.
Does that fuel pump work off vacuum?
Do I need to rebluid the carbs?
