Got on ski and turned on gas, It started fine, then when I accelerated it cut off. Then when I switch to the reserve tank it ran normally. Can anyone advice.
Look for the blue sludge around your gas fittings and your selector value, if its there, be careful about running the ski, it will run lean and cause big problems. Check and replace your fuel lines if you see any blue sludge. - also check your carbs
