Help please. I had the same "run then die" as a previous thread here. After the 3rd trip to the lake, I noticed that I wasn't using any oil. Tank still full. Hoping that I hadn't scorched cylinders, I checked and seems ok. Hot warning light never came on. Disconnected the tree oil feed lines to carbs and ran again to test. NO OIL FLOW. I have flow in the oil supply line from the tank to past the filter. Because of the carb bank, I can't see the device that splits the flow into three carb feeds.
Is this device run by vacuum? Is there a simple reason that I'm not getting flow to the carbs? Anyboby?
