Hi guys, new to here. Hoping for some technical help. I have a 1997 Waverunner, it has developed a problem where it will idle & accelerate under light throttle but as soon as i give it a bit more throttle or have 2 people on it it starts to die. If i get off the throttle it will keep running or sometimes i have to play with the choke a little to keep it running. I have drained the fuel & oil and replaced with fresh. Changed both plugs. Still the same thing. It almost seems like it is starving for fuel. Does it have a fuel pump or filter? Anything i should be checking, sound like a common problem.
If it does stall out it will take a bit to get it going again.
Thanks in advance
Criddy72
Thanks in advance
Criddy72
