Hey guys,
My GP800 has an issue when its running out of the water, it used to start up and idle fine(Sometimes it would raise the RPM a little itself). When you gave it throttle, it would spin up to about 7-8k maintain the RPM it was rev'd to. If you kill it, it dies as normal.
Recently, its been taking longer and longer to turn it over to get it to start. This last time, i turned it over until the battery died. i had to hit it with starter fluid. IT started right up after though.
No loss of power when in the water. takes right off. There is also a hard vibration at idle(Only in the water) that seems to be a shotty prop i think.
leak down test? air box leak? carb adjustment? bent throttle plate? im not too familiar with 2-strokes.
