I have a 2 1998 tiger sharks that’s I’m trying to set back to factory settings.
First ski- The front carbs high speed screw was turned out 2.5 and the rears was 3/4. I’m only having issues under full throttle and both plugs look a bit wet and oily. If i adjust the fuel on off switch so it’s barely open it runs great. I’m assuming this one is running rich on the front cyl. So dial back the front carb to the same as the rear ? Or do they have different settings ?
Ski 2 - Similar problem but if you pull the choke while under full throttle it runs great (starving air) so this one needs more fuel - I need to pull the carbs and check the adjustments.
Both skis my issue is only at full throttle. Anyone have the factory settings. Both carbs have been cleaned and rebuilt.
I’ve got exactly the same scenario on a 96 tiger shark right now. Runs better with choke partially engaged
