Found the oil leak in the ultra 150. It was a hairline crack in the main line from the oil tank right at the oil pump. Fixed that then changed all the oil lines. Then I found a water leak at the bottom of the big bell housing gasket of the jet. The big rubber hose to the housing doesn’t leak. Going to take it apart and check that out. Ski runs really good considering small water leak inside on jet.
Now about the zxi1100. Replaced rubber air intakes and took it out. It Still has the hesitation and loading up at low end. I can’t tell if it’s a lean stumble or rich bog? I guess I need to try lower end 45 jets from 50 and try leaner? I don’t have any higher than 50. Remember the stock ones were 35’s.
Also would you recommend the temp sensor bypass mod?
Anyway going to fix water leak on 150 and scratch my head on zxi1100. Any other ideas on 1100 low end problem? Once it clears the low end top end is great. Thanks.
