If you sand off the sharp edges on the combustion chamber, the
damage will not cause a problem. But don't scratch or sand the
head gasket surface.
The crankcase is what worries me. Sometimes when a rod fails
it beats the cases outwards and lowers the center gasket surface.
If the center gasket surface has a dip, it is possible for the case
sealer to be ejected.
Most likely the piston fell apart, not the rod bearing. Should test
the cases on a flat plate (pane glass) with 220 or 320gr emery
cloth lightly glued with 3m spray 77.
Bill M.
That engine also had hard starting problems and sometimes a
damaged fuel pump check valve.
Bill M.
