That is a return line jet. Watercraft use a fuel line that "returns" fuel back
to the fuel tank only at an ~idle. If there was no return line, the fuel pressure will
cause the engine to run rich at an idle. After the idle, and as rpm increases,
the return line is less effective because the engine is consuming nearly all
the fuel from the fuel pump.
On carb racks with only one fuel pump, it is common for the carb closest
to the pump to have no return line jet. In this configuration, only the last carb
needs the return line jet.
Fuel comes into the fuel pump and is pressurized, and supplied to the nearest
needle and seat. The fuel is then supplied to the next needle and seat through
a passage way or connecting hose, and the process can repeat until the last
carb (where the return line (hose) attaches to the carb). The last carb will
have the return line jet. This configuration supplies the same pressure to
all carbs.
If there is no return line jet, and fuel is allowed to flow back to the fuel tank;
there is no fuel pressure, and the engine does not start.
Look at your carb rack, fuel should enter the fuel pump and then be distributed
in series (1, 2, 3) and then restricted and returned. Either there is a logical supply
and return network, or a restrictor is missing, or the carb rack was disassembled,
and reassembled in the wrong order.
Bill M.
Sorry I can't do better, I have not worked on stx since ~2005. But all the CV
carbs for the 1100 had problems starting after sitting for a week or so. Many
were always hard to start.
