thanks for the reply! the ski is new to me, and I'm still trying to figure it out.
I found and downloaded the owners manual, and finally found where to hook up the water. My connector thing doesn't fit with the o-ring that's on there, I'm going to get a new o-ring for it.
Its been sitting for a while so I'm going to do fresh oil, filter and plugs before I run it. And I'll probably do fresh oil again after that.
I guess I'll have to double check, but do you guys do filter at every oil change? or just do the 2.5 qts? (owner's manual said 4.xx qts total with filter, is that right?)
Lets say I do oil and filter, will I need to suck the oil out of a different spot before I remove the filter so I don't spill oil everywhere?
Then when it comes time to fill it back up, if I've changed the filter do I still only add oil at the tank? will it make its way down?
I'm going to suck the fuel out of the tank too and get some fresh fuel in it.
