ok so i found the part i need in order to block the hole from where the oil pump gets removed. but do i need to or can i take the oil tank out? if so, how would i keep the computer from thinking there is low or no oil? also would i have to do something with the brass fittings on the side of the carbs where the oil hoses came off of to prevent excess air flow or should i just leave them on?
thanks for the help
thanks for the help
