1 - 7 of 7 Posts
New to the Yam GP1200R. Have a question with starting. Got this waverunner with a seized center cylinder for cheap. Engine was out. Had the cylinder reworked and put it all back together. Re-installed engine this weekend but I can't get it to start. It has spark, new gas and I bled the oil pump. It cranks but can get it to even try to start.
Seems like a fuel issue. Is there a fuel pump or does the cylinder vaccum pull gas from the take. It has side draft carbs so I don't think they can gum up like carbs with bowls on them (typical motorcycle carb).
Any ideas on things to check.
Discussion Starter · #2 ·
One more thing to add is that it beeps twice as soon as I hit the starter and the red warning light is on when it beeps, but turns off while still cranking. Is that normal when starting one of these GP1200s?
installing a primer on the fuel return line will prevent any hard starting in the future,,
hunterbear threres no security features on any gpr 00-08
remys right
If you have aftermarket carbs, you need to prime them with a plunger pump. Its a little tip with a hole usually on the left of the carb, to prime the fuel.
1 - 7 of 7 Posts
