Trying to get the ride plate off to try and fix the porpoising that's inherent with this ski. Got 3 of the bolts out. The 4th just spins. Won't come out. I think they have a sleeve on the inside attached to the fiberglass that has apparently broken loose. The problem is when they build these, they put big gobs of goo on all the bolts and openings. This goo is hard as a brick and is covering whatever has broken loose. I've tried putting vicegrips on this patch of goo, but whatever is inside keeps turning. Can't really get to that gob unless I remove most of the exhaust system in the back. Tried heating the bolt...no luck. Tried using pliers and pulling pressure downward on the bolt....no luck.
Any ideas?
Any ideas?
