Hello all, im new to ski's not to engines. I just purchased this 1100, i rode it around before buying as did seller, first time out afterwards it starts cutting out and shuts off after running 15 minutes or so, did some checks, think cooling is fine, water is flowing thru emm, seems as thourh only getting spark outta #1, ive switched the ignition wire to them and still only #1 so dont think its the packs, crank sensor ohms same hot and cold, no engine light, just battery light when cranking, even with jump pack or charger on it, wiring all good and tight, clean ski. thanks for any help. ps, had water in stator some, pulled it cleaned it all and resealed, still same issue runs great first 15 mins
