Was out for a ride and it stopped running while out, need help solving issue, engine turns over it receives gas and oil, good compression, so far I've tested resistance in primary and secondary ignition coils up to spec, engine ground is good, relay resistance was good never had a chance to test volt drop while cranking, tried unplugging mfd, kill button never worked but unplugged it anyways to try, still nothing thinking it's a stator or cdi issue how would I test those? The exciter coil in stator tested 5.5 ohms
