Have a 2000 stx 1100. Found Kadiag and build a cable. Communication is working. Decided to grab the codes since the previous owner told me it needed a new emm. I screen shotted the codes and cleared them. Ran static test on the injectors. 1 2 and 3 all clicked... ran the ignition test and only cylinder 1 would fire my test light. The coils on 2 and 3 fired when i moved the coil wire from 1 to 2 and 3. Deciding to attack the fuel pump code i started to look at that test... good voltage at the plug... but now none of the injectors fire on static test and even the ingition test wont fire on #1. Cleared the codes again and now im getting 51..52.. and 53... does anyone have any ideas where i should start.. or maybe the EMM is toast and needs repaired... thanks for your time...
