Just put new SBT engine in. Have two issues need help with. When I turned the shaft for the impeller I felt a little nickking when turned. Would rotate then nick. Also how do I go about adjusting the servo motor cables to the power valves. I can rotate the servo motor in both directions. Need procedure for final adjustment. At what position should the servo motor be before final cable adjustment. thanks.
