I just got back from riding my waverunner, now it won't start. It cranks over but does not start, any ideas? The fuel filter looks a little dirty but not much.
You need fuel, compression, and spark. Assuming you are getting compression, since it is turning over (unless you blew the engine last time you were out), then it has to be a fuel flow problem or no spark. Pull the plugs and confirm that you have spark first. If you do, you most likely have a fuel flow problem or crappy fuel (water, etc.). Could be crap in the carbs., so you might have to do a cleaning.
