My engine runs lean??????? Which means??? Is good or bad?????
F flrod105 · Registered Joined Mar 29, 2011 · 2 Posts Discussion Starter • #1 • Mar 29, 2011 My engine runs lean??????? Which means??? Is good or bad?????
Ernest T · Registered Joined Aug 17, 2009 · 3,033 Posts #2 • Mar 29, 2011 Usually means a problem with the carbs. Time for a carb rebuild? Running lean is never good for long. You will eventually destroy a piston/cylinder at the very least.
F flrod105 · Registered Joined Mar 29, 2011 · 2 Posts Discussion Starter • #3 • Mar 30, 2011 $$$$$ how much we are talking about $$$$$ for a rebuild carb....
Y YamaDoo · Premium Member Joined Aug 18, 2010 · 1,054 Posts #4 • Mar 30, 2011 flrod105 said: how much we are talking about $$$$$ for a rebuild carb.... Click to expand... Around $200, still much cheaper than rebuilding your engine.
