Have a 2001 GP1200R that already had top end rebuild done last year and ran great for a year but now has acceleration lag at mid throttle.
at low speed when throttle opens up 1/4 throttle acceleration seems normal but at half throttle there is a lag and seem to load up and bog down and as a throttle opens wide open about a second later it fires off like shot out of a canon. Compression and top end speed is normal.
Being a 2 stroke it always had a great top end power band but the total drop out mid speed is definitely way worse than before.
are there any carb adjustments that can be made as it seems to load up on fuel mid range or is the solution here only to do carb rebuilds?
