I all, I have a 2001 Sea-doo GTS. I noticed that the 'PTO' fuel pump attached to the carb was not pumping fuel as it should (a small squirt of fuel when the throttle is initially pushed).
So I read some of the testing procedures and descriptions in the service manual and found that the problem is likely the check valves are seized. So on one side (intake) the check valve partially works. I can see the little spring and ball in this side and it moves, although doesn't completely seal when I suck on the inlet.
The outlet side I can't see anything though the tiny holes and there's no check-valve action at all (i.e. I can blow and suck though the outlet with ease)
I'm the process of boiling the assembly in vinegar which so far is not helping. My question is are there for sure check valves on both these ports? Or am I just wasting my time trying to get them unseized?
Thanks!!!
Thanks!!!
