I have a 2002 Freedom with a cracked hull. It was reapaired and it doesn't hold up. Looks like a replacement hull is in order. Does anyone know if the Virage hull is the same?
What happens during the repair, I've never seen one that couldn't be repaired.
Anyway, they are virtually the same hull. I would just verify the mounting plate is the same for the engine, everyhting else should transfer with no issues.
Thanks for the reply. The crack is now about 3 feet long and is where the hull transitions from the curved bow to the flat bottom. It was enlarged and all loose material scraped out before being fiberglassed but it cracked again. Seems to be a high stress area taking the pounding of waves etc.
I will keep looking for a hull and will consider the Virage hull if I can get a look and measure the engine mounts before buying.
