I have 2002 Yamaha GP1200R and i have change the ECU wiring from 2000 GP1200R. (Both were the same body units) Every time i start the jetski, cluster only showing Temperature iconr and keeps Beeping non stop, when i press Start button again while its running cluster turns on, and cluster is working? Only was changed is the wiring nothing else. Wiring was reconnected the same way the old one was. This was changed do to wires got melted.
Read Only
I would say you have a electrical issue somewhere. Did you find the cause of the melted wires ? That's usually caused by a short somewhere. Might also double check all the connections.
