Hello everyone,
Just picked up a 800 XLT for super cheap. PTO cylinder has low compression and it has been sitting. Just wanted to get general advice in what to focus on. I have worked on a bunch of seadoos but this is my first yamaha.
My plan is
1. Take off carbs and clean. I have all the stuff to test and will determine if I need a rebuild kit
2. Inspect jet pump
3. Drain oil and fuel and replace with new.
4. Tear into engine and do a top end if not too bad. Is this a good idea? Or should I do a full rebuild?
What else should I look into? Should I switch to pre-mix on these? Etc.
Any advice will help just do not know too much about these machines and don't want to forget something that could hurt later on.
My plan is
2. Inspect jet pump
