I may be buying a 2004 Aquatraxx F-12X with less than 200hrs on it, a MacsBoost Intercooler and module and Solas impeller (I think it has an aftermarket intake grate as well). I know the people that have been using it and know it's been meticulously cared for, and has had very few problems. Two MAP sensors, wastegate control solenoid and routine stuff like spark plugs. What would be a fair price for it?
Is it possible to replace the cluster in the 04 with a 2005 GPScape cluster, or will the ECM freak? If the only problem would be the ECM, I would imagine it would be possible to swap the 04 ECM & cluster for the 05 counterparts.
What other mods could be done to improve it? Would a F-15x powerplant physically fit in the hull?
Is the ECM similar to (or the same as) one that would be found with the same or similar engine in a Honda car? Reason I ask is would it be possible to add a OBD2 DLC to be able to read realtime data like you would a car for diagnostics?
