1 - 4 of 4 Posts
Have a Yamaha FX HO and installed a fresh battery; won't crank at all, no dashboard readings, only green security light. First time this has happened. Any thoughts?
Sounds like a low battery or a battery with insufficient amps to crank the engine. Have you checked the voltage? Also check that the battery connections are very tight.
My 07 vx acting the same way. It has a fresh new, charged battery. I can hear it trying to do something inside the fusebox.
I am having the same issue now. Do you ever get any resolution? I install battery, and green security light illuminates. I hit start, there’s one click, and then everything goes dead.
1 - 4 of 4 Posts
