I have a 2004 Honda R12 that quit out on the lake.
I have been doing some troubleshooting. It turns over fine.
I noticed that I could not hear the fuel pump when you put the landyard in. It usually has a pump priming sound.
Fuse is good. I have a 2nd one so I swapped the fuel pump because I know that one works. Still no priming noise at the start. I took my meter an I get 12volts at the plug when I pull the landyard. I also switched the main relay and nothing changed.
Has anyone had a problem like this.
Is there something else in the circuit that can prevent the fuel pump from coming on?
Thanks,
RJB
