Last week, i went to the beach with my ski and after about an hour being off, the ski wouldn't start, it would crank about one or two rounds, but not enough to make it start. My Friend towed me to the shore at idle speed and when I looked at the ski, I Found water in the piston. I turned the engine without the Spark plugs to evacuate the water and at That point, the oil looked like New. I then went to the Lake to run the engine a little, and found water in the oil after running about half an hour.
I am not a mechanic, i read that i only have to do two oil changes to drain the milky oil and have New one, is it complicated? Should i bring it to a mechanic?
Any help would appreciated,
Thank you!
Thank you!
