My throttle was very slow to return, so I started checking the cables, they seem fine, then the carbs and oil pump. I noticed the oil pump has a slow return when turning it manually. The front carb has the same issue, very slow return to the normal position when manually moving the linkage. The back carb returns super fast, just like normal. Any ideas ? These findings are with all cables disconnected. I think the shaft is bad on the front carb. Looking for some advice. This is a 2 stroke, 2 cylinder.
Thanks for the help, Mike
