Hi folks,
On to my ongoing saga trying to get my 05 STX 12F running properly.
A few questions:
1) Will the ski run with a bad CDI computer?
Here's the problems I have been having: I have two "identical" 05 STX 12Fs. One runs great, the other doesn't.
Differences:
1) When I turn the key switch ON, the good ski beeps twice as the display goes through the self test, and beeps twice again when the ski is ready to start. The bad ski, doesn't beep at all, but the display goes through the same self-test in the same amount of time.
2) The bad ski registers 0 MPH all the time. I swapped speedos between the two skis, and the speedo sensor is ok, bad ski still has 0 MPH all the time.
3) The bad ski won't rev past about 5000 RPM (seems to be some sort of limiter cutting in), and confirmed it is not in SLO mode
4) All other display functions on the bad ski work correctly (or at least the same as the good ski)
5) The spark plugs on the bad ski look like it is running rich. Could that be related to a timing or EFI issue from the CDI computer not getting the right information from the "system computer"?
Any other ideas anyone? I took it to a local dealer who said "yep, the display computer isn't working correctly", but they couldn't defintively say that was the problem and wanted to swap computers between the two skis to see if that fixed the problem (Gee thanks, at $90/hour to figure out if that was even the problem).
Thanks in advance for any help!
A few questions:
Differences:
