I have a 2006 yamaha waverunner fx cruiser 140 that is having some idle problems. It runs perfect if you are going or giving it gas but at idle it will only run for a few seconds and cut off. It has no problem starting back up but will repeatedly die if you dont give it throttle. It seems to run fine on the trailer untill I turn the water hose on and it will cut off. It may be a water temp. sensor or just needs idle adjustment, I dont know can anyone help? Thanks Jay
