ok here it is hope someone out there will help 2007 Yamaha waverunner will not run
new battery ,starter selinod , pulled off fuel line from ingector gallery pumps fuel . It will run if I jump at starter relay but will only run on starter fluid then dies .
Hope someone has had the same problem or that someone out there can help with this issue
Thank you for your time
