Personalwatercraft.com reviews the 2008 Honda F-15x. Be sure to read the article and let us know what you think of this new machine
For the first time since entering the personal watercraft market in 2002, Honda has built a brand new vehicle from stem to stern—the F-15X.
With a new, more powerful engine and a longer hull, the F-15X is Honda’s answer to the recent PWC innovations from Sea-Doo, Kawasaki and Yamaha.
The F-15X is powered by a new 16-valve 1,470cc turbocharged four-cylinder engine, which is a big jump from the 1,235cc unit powering the F-12 series. Despite its power, Honda says the efficient, low-emissions 4-stroke design burns up less fuel than a comparable 2-stroke.
Ok, we've heard all the hype now what we need is someone who has actually ridden this ski and can tell us how she does in big chop!! The asking is arrogantly priced! We need Kevin to ride this baby and let us know how she handles...people will not put out $14,000+ if they don't see any reivews! What's the problem Honda?
If I replace my instrument panel with a new/newer one, is there a way to correct the hours if the replacement has less hours? Or is this data stored in the engine computer and will be correct when I replace it?
-Chris
2007 Aquatrax F12
I have a 2007 F12X and at times the ski will run 60mph and sometimes it will only run 50mph. It doesn't seem to be misfiring and runs good otherwise. Does anyone else have this issue?
Today I was out riding my 2004 Honda aquatrax r12x and was running down the river probably a little more than idle around the same area i had been a week before. well turns out the water level had dropped some and I run up on a gravel bar. and I sucked a few rocks into the intake and heard them...
Im looking at buying two 2004 Honda Aquatrax R12x on a double trailer with covers. Both have around 150 hrs give or take and look to be in very nice shape. hopefully going to look at them this weekend. The seller say one runs and operates perfectly fine the other needs a pgm and that its...
I just purchased a pair of R12x and went to check the oil on them. After doing some research I found out there are two places to check the oil. I check the oil at the fill area and it wasn't touching the stick on either skis I checked the oil in the back by the turbo and on ski (number one) it...
