1 - 9 of 9 Posts
As the title states, I have a 2008 VX 110 sport. It cranks and run great. Since it is a sport model, there is NO security system. I have replaced my display with known working display, still no luck. I have removed EVERY fuse behind the cap and the are all good (looks like left side are spares and right side is active as I am looking at the fuse box straight on.) I have my safety key in place and have checked with my test light EVERY wire going to the display. I have NO power going to the display.
Any idea where the switch is or what relay sends power to the display when the safety key
is inserted? I think if I can get power. it will be just fine.
Thanks,
Sonic1954
· Premium Member
Did it used to come on without the engine running ? Some displays don't. I will try and find some info. In the mean time, check all the connections and make sure there is no corrosion and all the grounds are clean and tight.
Discussion Starter · #4 ·
The connections are corrosion free. Battery is charged at 12.5+ volts. In the past, it came on as soon as you inserted the emergency kill switch. Now it NEVER comes on.
From the diagrams you attached, it must be getting power from the ecm. The buzzer, fuel sensor, and speed sensor would only consume power. Ill look further into that next weekend.
I am only at the lake on weekends.
Thanks for the assistance. I'll try and update next weekend.
Sonic1954
1 - 9 of 9 Posts
