Hi guys after some input I bought a seadoo 2005 rxt with a sexier engine due to not being winterised so I’ve no sprinted and rebuilt and now all back together and back in the ski.
Had no issues with the rebuild as I’m a marine engineer myself. Had to replace the ecu as the pin in the ecu had corroded as the exhaust sensor wire had corrosion track up the wire so my question is the ski would run on my old ecu with no issues apart from the exhaust sensor causing it so alarm but now with the secondhand ecu it will take ages to start and needs throttle to keep it running seems like it’s over fuelling as the plugs are black when I pull them.
Do these Ecu’s need coding my ski is a 05
