I have a 89 650sx that was running great until this afternoon. I ran over a reed and it sucked it up and it shut off right then. So i got off pulled the reed out and it ran fine for a second. Then after that it would run fine then bog down and die. It wouldn't start for a while then it turnover a few times a then barely start going then it start going pretty fast almost top speed for probably 3 or 4 seconds then die, and i did that the whole way home. What i was thinking is that there is a clog in the fuel line and when you let it sit for a minute it would slowly drip and fill up the carburetor bowl and then run on that and die once it was out.
Anyone else think this could be the problem, or something different? Is there any relation to the problem now and the reed that got caught in the impeller?
If there is a clog in the fuel line should i just take out the lines a blow them out and thats it?
Thanks for any help.
