I'd like to bypass the oil injector and move to pre-mix. I've googled and found a block off plate for sale that apparently blocks off the space where the oil pump is located.
I understand I should zip tie the oil tank sending unit float to the full position and to run 40:1 pre-mix.
Is there anything else involved with going to pre-mix?
SD
SD
