Thanks for your reply,
To reiterate, when the engine is turning the shaft from the back of the block right through the hull to the impeller is turning, what is not turning is the impeller. I assume from what you just wrote that the splines on the impeller have rounded or possibly the captive nut is loose. How do I get to the impeller to check? From the rear or from underneath?
