This is my first post so bear with me. I have a 1985 JS440 and had a couple of the magnets fall out of the flywheel. Surprisingly, there was little damage done to the stator. I found a flywheel that had magnets in good shape and glued them into the original flywheel. I know, it probably wasn't the greatest idea, but it was a quick fix. After putting the motor back together, I have spark, compression and fuel, but no firing. Not even if I put a little gas in the cylinders. Is it possible that it isn't firing at the correct time. If so, does anyone know how to check when the plugs are firing? I haven't made any adjustments to the electrical system, and it was running fine before the magnets came unglued. Any help would be greatly appreciated. Thanks.
