does anyone know where the compression should be at, on a js300?
R rseeguy · Registered Joined Mar 16, 2008 · 4 Posts Discussion Starter • #1 • Mar 29, 2008 does anyone know where the compression should be at, on a js300?
3 302 much · Registered Joined Mar 19, 2008 · 23 Posts #2 • Mar 30, 2008 440s are like 150psi, so probably 150 ish.
R rseeguy · Registered Joined Mar 16, 2008 · 4 Posts Discussion Starter • #3 • Mar 30, 2008 ahh ok.... thanks for the info... i just did a compression check on the js 300 & its at about 123psi at the moment... thanks again
