Im having trouble getting this thing to idol. It will start if I shoot carb cleaner or starting fluid in it and I can usually get it to keep running if I work the throttle. I took the carb off and cleaned it and still nothing. Ive tried messing with the high and low settings. Once I get it to run with the carb cleaner (it normally wont start with out it) and it runs, it will start for a a second and then die. If I try to give it gas it just bogs down and quits. I have the little one barrel carb.
