1 - 5 of 5 Posts
I have a 91 kawasaki js550 and i have replaced the starter solenoid, checked the start/stop switch and have checked all connections. Battery is brand new and have charged it up. When i go to start it nothing happens at all. Any help would be great
Have you checked your ground(s)? Start simple and eliminate from there.
Nothing happens at all when you hit your start button? Not even a click?
I had run into similar problems like this in the past. Each time I traced it back to the start button, it just did not make contact to engage. When you say you checked the start/Stop what did you do? Many times if I just open the housing and reseat the switch I was able to get it to engage.
I have the same issue, but I do hear a "click" near the electrical box. Suggestions?
Battery is fully charged. After hitting the start button repetitively, the engine turned over a couple of times, but now I have no response, just a click. Thanks
With a volt meter and a known good battery the starting circuit can be tested in a matter of minutes to determine the culprit. These circuits are very simple and easy to repair.
1 - 5 of 5 Posts
