Anyome pull the tray or locker under the seat out, I tried but it is like glued on or really stuck, if there is a secret someone could let me know? Also, I found a tiny washer when I was putting the flywheel cover on and couldn't figure out what it was till now, after looking at the diagram I think it goes with the spring in the cover that pushed the idle gear back, that means I got to pull it back off to check, DARN! I see the hose fitting to hook water hose is a white fitting with a rubber o ring and it has a small tip with a hile that is spring loaded, I'm guessing there is an end to buy that fits on the hose to mate up with that?
rhutson
rhutson
