I got this wave runner a couple years ago and have not been able to get it to run right... yet! This is my first ski and admittedly, I'm not a motorhead.
Engine turns over and seems to run good, but on the water I can only get it to about 11-12 Mph full throttle. If I run it for a while and shift my weight forward it can eventually plain out and I can increase speed to 22-25Mph and hold it there until I crash a wave or turn too sharp. However, I read this can do 30-35mph top speed.
Gas is good, getting spark on both plugs, carb seems clean, but have not taken it apart to inspect thoroughly. Prop seems a little worn and dinged and there is some gap. See attached pics.
Before replacing the prop, is there any other things I should check that would be cheaper and easier to fix? Can the prop be adjusted to fit the gap better?
