First I would like to say that I have read all the engine runaway threads. The differance with mine is, it shuts down with the kill switch. It doesn't stay running like in all the other threads. As soon as I start it, it goes to full RPM and just bounces off the rev limiter(ging, ging, ging, ging). I have performed an engine leak down test and there are no leaks. Compression is good: forward - 155 and aft - 148. The carbs: in the manual has 1 1/4 turns for the high speed screw and 2 1/16 for the low speed, this is what I have set it to for starters. I have a carb rebuild kit on the way. Is there anything else that this could possibly be?:smilie_help:
